EAGLE User Support (English) Eagle 5.11
  • Views 248 views
Eagle 5.11
Eagle 5.11  question regarding  ground interlayer?
How do I keep the copper away from a TO220 transistor area with in the Ground layer?
    "Bill Basham" <communitymanager@premierfarnell.com> wrote in message
    news:800474576.12411324066801172.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    Ground layer?
    If you are talking about using a ground plane and keeping the ground away
    from the transistor's tab, I use a polygon of a different ranking. My
    predecessor had a love of using rectangles for the heatsink area. Trouble
    with that is that rectangles (iirc) can not have a signal name. It works but
    has design rule violations that you have to accept then. There should also
    be a keepout area under the tab.
