EAGLE User Support (English) Library upgrades.
  • Answers 2 answers
  • Views 548 views
Library upgrades.
Dumb question time.  I have a couple libraries that were created in eagle V2 IIRC and need to know how to update them to a newer version.  or an I giong to ahve to find an old version print em out and recreate them?
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Am 26.12.2011 21:48, schrieb tregare:
    Yes IIrc= If I Recall Correctly.  the libraries were created in 2.0 or 2.1 possibly    I no longer have a machine with 2.x on it and didn't know about the SCR export.
    I had switched to KiCAD on my windows machine but it does not run properly on mac so I am re-evaluating EAGLE on macintosh.
    Then convert the old files using the mentioned "update26.exe" delivered
    in all eagle downloads found here:
    ftp://ftp.cadsoft.de/eagle/program/4.0/
    AFAIK you must put the old files into the same directory where "layers
    new" and "update26.exe" are located, usually "/bin".
    Under windows you must open a DOS-window, go to that directory and type
    update26 filename.sch
    I dunno if this runs on different machines other than windows.
    Joern Paschedag
    I believe he means "Version 2 If I Recall Correctly" -- some of our
    acronyms don't translate too well sometimes image
    mikey
    Am 22.12.2011 08:31, schrieb tregare:
    I have no idea what version this "V2 IIRC" is, but in the eagle/bin
    directory is a program "update26.exe" that should convert things from
    versions before eagle 2.6  (in Eagle 4.x /5.x). There are ulp's
    "updatemanager" or so in the cadsoft download section.
    "Normally" one just exports a library as a .scr file, starts a new
    library from a newer eagle version and imports the .scr file.
    Joern Paschedag
