EAGLE User Support (English) Errors in Gerber Data
  • Views 681 views
  • eagle
  • pcb
  • pour
  • gerber
  • question
I have just started using Eagle and am evaluating the Freeium version. It was all going good until I finished my test design and tried to generate some gerber files. I used the Spark Fun CAM set-up and it created the gerbners just fine. The problem was when I checked the output using an online gerber viewer.
When checked I noticed that I was getting big gaps in my top side plane (which is a +5V plane) and whatever setting I seem to use I can't get rid of it. I have attached a picture with the eagle .brd file on the left and the gerber data when viewed with an online gerber view on the right.
Does anyone know ehat is going on?
Cheers
Martin
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Martin Smith wrote:
    Eureka!
    I think I found the problem. I turned off the 'poc Coord' tick box in
    the CAM settings and all the gerbers were created OK.
    So my next question is what does this option do?
    Martin
    Assuming 'pos.Coords' see the manual section 'Preparing Manufacturing Data'
    / 'Set Output Parameters'.
    I feel you have found a bug that needs attention.
    Warren
    news.cadsoft.de
    Eureka!
    I think I found the problem. I turned off the 'poc Coord' tick box in the CAM settings and all the gerbers were created OK.
    Martin
    Thanks. I downloaded V6.1.1 and I still get the same problem. I have tried moving components, renaming the polygons, drawing in fresh polygons, changing the shape of the poygons and trying only 1 polygon per layer. Nothing worked and I still get the same gaps in the same places.
    Very annoying...
    Martin Smith wrote:
    Thanks for the reply.
    I am using Version 6.1.0 for Windows - does this have issues as well?
    I think it is the latest release?
    Martin
    V6 has numerous issues.
    There is a 6.1.1 beta available. Have a look at the 'eagle.betatest' forum
    to see the list of fixes it contains.
    The betatest forum is where many people report issues so a read through
    there, as well as 'eagle.supprt.eng',  keeps you up to date with issues
    being found.
    Warren
    news.cadsoft.de
    I am using Version 6.1.0 for Windows - does this have issues as well? I think it is the latest release?
    Martin
    Martin Smith wrote:
    I'm guessing you are using Version 6.0, as you haven't said which version of
    Eagle you are using.
    Version 6.0 has Gerber polygon issues.  Move to Version 6.1
    Warren
    news.cadsoft.de
