EAGLE User Support (English) Symbols, Package, Devices Editing ?
  • Views 757 views
Hello All
I am new to the community and software. I have some Q,s and hope for some A's!
While creating a schematic, symbols, packages, and devices it seems to be way
to difficult (remember I'm new at this). While placing a component in my schematic
I get this huge assortment of libs (very nice) that has almost what I want. It will have
the schem symbol that I want, but the package footprint isn't. Is there an easy way
to pick a generic symbol, and then a package you want, and then associate the two
to make a device...correct?
Respectfully
VanC
    Hmmm - for some reason I can't find an edit button ... need coffee I guess
    .. anyway, here is a link to creating your own library part at
    Instructables that I found helpful in the past.  There are also some out
    there on modifying an existing library.
    http://www.instructables.com/id/How-to-make-a-custom-library-part-in-Eagle-CAD-too/?ALLSTEPS
    mikey
    I have done that in 5.11, it worked fine for me.  One thing to be aware of
    (I don't have Eagle running right now) - you can add search paths for
    libraries in the options.  That lets you put your libraries that you have
    created in a different location than the Eagle libraries so they are safe
    from upgrades etc.  You can have your libs either under your personal
    directory or somewhere else on the disk, but they can be in a different
    location which means you don't delete/overwrite them with Eagle.
    mikey
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Robert Rademacher wrote:
    I tried that method - didn't work.
    What Eagle version do you use? I have 5.11 version here.
    The description Robert Scott gave was good and it works as described with
    v5.12  on  Windows. Version 5.11 was no different in this area.so should
    work also
    Warren
    news.cadsoft.de
    Robert
    Robert Rademacher
    Engineer
    VENDAPIN LLC
    On Wed, 04 Apr 2012 13:19:09 GMT, Van Couch <van.couch@petrodaq.com>
    wrote:
    >Hello All
    One way to do that is to make a new temporary library.  It starts out
    empty.  Then drag and drop devices and/or packages into this temporary
    library.  Now play around with editing in that new library to make a
    device your really want, either by starting out with an existing
    device you copied there, or by making a new device to which you add
    existing symbols and packages and then connect them up.  Once you get
    what you want, copy the finished device to a more permanent library.
    That will take only the symbols and packages you need for that one
    device.  Watch out for name conflicts if you copy the resulting device
    back into a library that already has devices, symbols, or packages
    with the same name (if you made any changes to them).  I generally
    don't change any of the Eagle libraries because otherwise it is
    impossible to maintain them through a version update on Eagle.  So I
    make a custom library, usually one for every project I am working on.
    Robert Scott
    Ypsilanti, Michigan
