EAGLE User Support (English) Anchor component to grid
  • Subscribers 189 subscribers
  • Views 459 views
  • on
  • grid
  • fix
thewizard83
thewizard83 over 14 years ago
I almost finished a circuit; but there are some components which are not right placed on the grid. The same things appens for wire so that placea node is impossible.
How can i fix the position of component or wire on the grid?
I tried to modify the dimension of the grid but it was unuseful.
Thanks.
    0 e14 Contributor over 14 years ago in reply to robotonics
    On 21.04.2012 17:02, David Cotterill-Drew wrote:
    A very annoying problem...usually happens when you change the grid size after already adding components.
    I am a practical person and find it best to either delete the board and start again, or change ALT to 'finest' in GRID display,and keep ALT held down when wiring so that you can get finer control of your cursor. image
    Changing the grid in the layout editor has no effects on the already
    placed objects.
    If you have to change the position of an object, use CTRL + MOVE in
    order to bring the component onto the current grid or change the
    location via properties or you could also use MOVE with coordinates
    in the command line, like   MOVE U1 (2.3  7.15)
    Richard Hammerl
  • robotonics
    0 robotonics over 14 years ago
    Am 20.04.2012 14:06, schrieb Paolo Perego:
    Try to MOVE the object not just with a 'normal' mouse click, but with
    CTRL+Click. See 'help move'.
    Andreas weidner
