EAGLE User Support (English) Modifying a downloaded board file
  • Views 532 views
  • board
  • eagle
  • pins
  • pads
  • jack
  • 2.5mm
  • 3
  • component
  • modify
  • change
  • trs
  • downloaded
  • 5mm
Hi, so i'm currently in the process of building my own motor control system using pc board files that I downloaded from the internet and have run into a problem with sourcing one of the parts. The part in question is a 2.5mm TRS female jack. As far as i can tell the specific jack needed cannot be bought in my country.
I have been able to buy a similar TRS female jack though but the problem is that the pin structure is different. Here is a screenshot of the original jack pin structure from the .brd file:
http://i47.photobucket.com/albums/f177/volcan199/Screenshot2012-04-24at21516PM.png
The five green pads on the left are for the TRS pins. The right one is not. Here's the manufacturer diagram for the original TRS jack showing the pin numbers:
http://i47.photobucket.com/albums/f177/volcan199/Screenshot2012-04-24at25408PM.png
This is what the TRS jack that i could find looks like:
http://i47.photobucket.com/albums/f177/volcan199/jack1.jpg
and here's the manufacturer diagram:
http://i47.photobucket.com/albums/f177/volcan199/JackDiagram.jpg
What I'd like to know is, how would i go about modifying the .brd file to accommodate the new TRS jack? I have never designed a pc board before and so I'm pretty clueless as to how i should do this. It seems like i need to find the library that this part is in but I cannot find it anywhere. I'm guessing it's because it's somebody else's custom library part that I don't have in my library. How can I edit this component?
Any help will be greatly appreciated
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Never mind, I saw there was an earlier post that was of a very similar topic to mine. It took a bit of trial and error but I managed to sort out my problem. Here's what my new component looks like:
    http://i47.photobucket.com/albums/f177/volcan199/Screenshot2012-04-24at44157PM.png
    oh and I'm aware of the fact that the TRS jack that I have found is 3.5mm instead of 2.5mm like the original but this shouldn't be a problem because if I can get this new jack to work, I can just use a 2.5mm to 3.5mm adaptor on it.
