EAGLE User Support (English) User Interface Language Selection
  • Subscribers 189 subscribers
  • Views 1699 views
I would like to ask, how can i change the language that i prefer in the software?
I guess EAGLE PCB now automatically detect the language using in the computer and change it, but i prefer to use another language instead, how can i change it?
Thank you for your attention.
  • rachaelp
    0 rachaelp over 10 years ago in reply to e14 Contributor
    Francesco Fontana wrote on Thu, 18 August 2016 11:56
    It doesn´t work, I wrote in the command line SET LANG=en_GB but I
    always get the program in german, the place where I live. I remember in
    Linux I had to change the LANG variable in many different places. Do I
    have any othe environment variable ? Thank you.
    Francesco
    https://www.element14.com/community/message/203919
    Hi Francesco,
    I don't run Windows unless I have to and with EAGLE I don't so I am only
    guessing but I suspect you might have to set the LANG environment variable
    within Windows in the environment variables editor in the control panel.
    Best Regards,
    Rachael
  • rachaelp
    Francesco
    Hi Francesco,
    Best Regards,
    Rachael
  • rachaelp
    Francesco
    Hi Francesco,
    Best Regards,
    Rachael
    Windows 7 operating system.
    It doesn´t work, I wrote in the command line SET LANG=en_GB but I always get the program in german, the place where I live. I remember in Linux I had to change the LANG variable in many different places. Do I have any othe environment variable ? Thank you.
    Francesco
    EAGLE reacts on the LANG environment variable.
    If you set  LANG=de_DE  you will get German language and help texts,
    for example.
    Richard Hammerl
