EAGLE User Support (English) Is there a way to delete multiple packages inside a library?
  • Subscribers 189 subscribers
  • Views 400 views
cosborne2000
cosborne2000 over 14 years ago
I was consolidating several old libraries and deleted references to many obsolete packages.
Now my new library has a very large number of unused packages.  I tried the remove command but I'm hoping for a more efficient way than typing each package name one by one.
The remove command doesn't appear to accept "wildcards" either.
Is there a method to remove groups of packages?
If the Eagle UI can't do it, is there a script or 3rd party utility for library management?
  • cosborne2000
    0 cosborne2000 over 14 years ago in reply to e14 Contributor
    Thank you for the script -- I'll give it a try.
    BTW, what is wrong with the web forum interface?  I had to access the message in the news group to see the script.
    Just to get this gripe off my chest---
    How is it that in version 6 after many years of development there is no way to do this efficiently in the UI ?!
    I don't expect Eagle (~ $800) to match my Altium (~ $6000) install but give me a break.  Deleting packages has to be this convoluted?
    Every new Eagle version gives me hope of a serious upgrade to the library management system --- when is version 7 coming out image
    here is the quick-and-dirty ULP I use for that purpose
    Lorenz
