EAGLE User Support (English) Just want to put parts on the board
  • Replies 7 replies
  • Views 1111 views
Brand new to Eagle but have used other tools. Want to lay out a board directly without creating a schematic. I cannot see how to put down an IC socket from the libarary. Pads and holes work fine but no parts.
- When I select  Library > Use and select "ic-package.lbr" nothing opens.
- When I select Library > Open, I can get the attached window but it is not clear how to drop a socket on the board.
Help please!
  • robotonics
    0 robotonics over 14 years ago in reply to e14 Contributor
    Brilliant!..of course...the answer staring me in the face...and I was looking for a way to turn off FB annotation..image
    Thank you for clearing that up!
    0 e14 Contributor over 14 years ago in reply to robotonics
    On 5/14/2012 9:10 AM, David Cotterill-Drew wrote:
    How?
    I have tried to add a package in the board editor, all I get is an error message ' Can't backannotate this operation, please do this in the schematic!'
    What did I miss?
    The schematic would need to be closed and consistency will be lost.
  • robotonics
    How?
    What did I miss?
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    jim w wrote:
    I am l not seeing the logic in this. I can create a board in layout
    mode - please see attached. Why would Eagle tie my hands and not let
    me add a part? This makes no sense. These are *not decisions Eagle
    should make, they belong to the designer.
    You do not have to create a schematic. Assuming the library of interest is
    USEd (Greeen dot beside it when viewed in the Control panel) you can add
    packages directly to the board. You dont add ,say, a 1N4001 diode, instead
    you select the correct package for the diode. From the board you select ADD.
    The USEd libraries will be preesent and from there you find the  package of
    interest and ADD it to the board. Once enough packages are placed on the
    board you use SIGNAL to connect pads. Then you ROUTE the traces.
    HTH
    Warren
    news.cadsoft.de
  • robotonics
    Why do you have issues with creating a schematic?
    You need to work with the tool or find one that fits your purpose better.
    I can give you advice on how to work with this tool, as I have worked with it for about 11 years now, creating hundreds of pcb's...
    I am with you on this point though, you should be allowed to at least switch off Forward/ Back annotation if you so wish, perhaps someone will take your suggestion...
    I can see no reason why you should not be able to, and I have tried to see if I could, even went back to version 5...no luck!
    Perhaps someone else here knows a way to turn off the FB annotate?
    I am l not seeing the logic in this.  I can create a board in layout mode - please see attached. Why would Eagle tie my hands and not let me add a part?  This makes no sense.   These are *not decisions Eagle should make, they belong to the designer.
  • robotonics
    You need to create a schematic, and ADD the part to the schematic...you will not be allowed to place the part in the board editor...See notes on Forward & Back Annotation...
