EAGLE User Support (English) Sparkfun footprint files for Eagle 6.2
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 879 views
I've found Sparkfun files for 6.0+ but when I tried to use them in Eagle 6.2 I get a message about
"Loading D:/Documents/SparkFun-Boards.lbr ...
Error:
line 5, column 6: This is not an EAGLE file."   Anyone have updated files for Eagle 6.2?
    Well that seemed to do it.  Guess I did download them some wrong way before.  Thanks alot now able to use em.
    Am 10.09.2012 04:06, schrieb Richard Waterman:
    Thanks for giving that to try but didn't help.  I wonder what version sparkfun actually uses to allow it to work.  Maybe they stayed on 6.0.
    https://github.com/sparkfun/SparkFun-Eagle-Libraries/downloads
    Here is a link for eagle6 sparkfun libraries at github.
    Maybe you downloaded the files directly and that won't work.
    A little above the list at the very right side you can see
    " Tags  Download". Klick on download and you are given the choice to
    download as zip/tar.gz file. After decompression the files are ready to
    use image
    Joern Paschedag
  • fritzz
    0 fritzz over 13 years ago in reply to e14 Contributor
    I seem to be able to load them just fine in 6.2
    Error:
    Open up that Sparkfun library with a text editor and view the XML
    There is a line near the top that looks similar to the following
    sparkfun/SparkFun-Eagle-Libraries · GitHub
    It has two starnge charcters in it. One after master and the other before
    GitHub. These may be causing the issue so take them out and try again
    HTH
    Warren
    news.cadsoft.de
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    I was looking to use them base on a tutuorial I was looking at related to Ardunino.  But guess I'll just have to do without since won't load in newer Eagle.  There was an Adafruit library that worked with newer Eagle and that does seem to have alot of Arduino componantes.
    Am 05.07.2012 00:43, schrieb Richard Waterman:
    Error:
    There are libraries available for eagle5.x and 6.x but I don't have a
    link right now.
    Anyway watch out they contain a lot of usually unwanted layers (set
    used_layers all).
    Joern Paschedag
