EAGLE User Support (English) How to use a .scr file?
  • Replies 10 replies
  • Subscribers 190 subscribers
  • Views 10787 views
gussabina
gussabina over 14 years ago
Hi:
I'm using a Samtec connector and downloaded a file from their web site in order to use the part in my Eagle design.
I realized they are not provided a .lbr (library) file as I would expect. Instead, they provide a .scr file. How to use this file in order to get the part for my design?
Thanks Gus
    0 autodeskguest over 9 years ago in reply to autodeskguest
    Am 01.02.2017 um 05:11 schrieb Warren Brayshaw:
    Joern Paschedag wrote on Sat, 21 July 2012 09:58
    Am 20.07.2012 22:30, schrieb Bob Moreno:
    Joem, could you be more specific as to where you run the command
    "Data/excute script" please.
    Thank you,
    Bob Moreno
    What is not clear in saying:
    "Open a (new) library where you want to import that part"
    IN the library you
    go to "Data/execute script" and navigate to the .scr file. The part
    will then be imported to the open library.
    The whole thing is done from the library editor.
    Joern Paschedag
    Hi all
    Possibly there's a difference between the English Eagle and the German
    Eagle
    On my PC I would have said File > Execute Script...
    Warren
    Yes there sure is but after almost 5 years he should have found out or
    RTFM image
    Joern Paschedag
    0 autodeskguest over 9 years ago in reply to e14 Contributor
    Thank you,
    Bob Moreno
    IN the library you
    will
    Joern Paschedag
    Hi all
    Eagle
    Warren
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • eelcoscheers
    0 eelcoscheers over 9 years ago in reply to e14 Contributor
    What more can you say ;-)
  • skyflyrr
    0 skyflyrr over 14 years ago in reply to e14 Contributor
    Thanks Jorge,
    Best
    0 e14 Contributor over 14 years ago in reply to skyflyrr
    On 7/23/2012 9:27 AM, Bob Moreno wrote:
    The part where you add "in the library" clears it up.
    We are all new at some point in using Eagle.
    Hi Bob,
    I don't think Joern meant to offend. I've been on the forum long enough
    to know that he's generally no like that. Sometimes things are lost in
    translation.
    Please feel free to always ask questions.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
  • skyflyrr
    The part where you add "in the library" and the part where you state "The whole thing is done from the library editor" clears it up.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Well excuse the hell out of me for asking.
    Joem, could you be more specific as to where you run the command "Data/excute script" please.
    Thank you,
    Bob Moreno
    IN the library you
    go to "Data/execute script" and navigate to the .scr file. The part will
    Joern Paschedag
  • skyflyrr
    Thank you,
    Bob Moreno
    Am 20.07.2012 00:52, schrieb Gus Sabina:
    Hi:
    Thanks Gus
    Open a (new) library where you want to import that part and go
    "Data/execute script" and navigate to the .scr file. The part will then
    Joern Paschedag
