EAGLE User Support (English) Problem with 40XX.lib
  • Views 540 views
Hi, I am new to Eagle 6.2.0 and starting my first small project using a 4017N. When making the schematic I place the IC and then find that I cannot make connections to pins 8 and 16 they are not listed in the IC. These pins are shown when you look at the 40XX.lib (4017) but not when add to the schematic. Does anyone know why this is or how I can fix the problem?
Thanks for any help.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Also don't forget that you don't use "wire" to wire the schematic, but use
    "net" instead (having made that mistake myself along with many others  image
    mikey
    Thanks that what I needed to know. image
    fix the problem? Thanks for any help.
    See HELP Invoke
    news.cadsoft.de
