EAGLE User Support (English) How to unfill a polygon after ratsnet
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 11423 views
  • polygon
gussabina
gussabina over 14 years ago
Hi:
Once you create a polygon for a ground plane, and after using Ratsnet, the polygon fills. How to get rid of the fill again (other than closing and opening the .brd again)?
Thanks;
Gus
    0 autodeskguest over 9 years ago in reply to scott.archer
    Am 09.09.2017 um 03:07 schrieb Scott Archer:
    to add...
    I find it very frustrating that the pour area re-fills every time I run ratsnest, and I have to ripup to hide it again.
    My solution was to add a keybinding (i used ctrl + D) and have the command run:
    RATSNEST; RIPUP @;
    This reroutes the airwires, then clears away the pour.
    Eagle 7.6.0
    https://www.element14.com/community/message/228497
    One usually puts "set_polygon_ratsnest off" (on) on keys image
    Joern Paschedag
  • scott.archer
    0 scott.archer over 9 years ago in reply to e14 Contributor
    to add...
    RATSNEST; RIPUP @;
    Eagle 7.6.0
    On 7/29/2012 12:34 PM, Gus Sabina wrote:
    Hi:
    Thanks;
    Gus
    Hi Gus,
    You can type:
    RIPUP @;
    Followed by enter in the EAGLE command line.This will return all of the
    polygons to outline mode.
    hth,
    Jorge Garcia
    Op Sun, 29 Jul 2012 18:34:51 +0200 schreef Gus Sabina
    <noreply-116942@element14.com>:
    Hi:
    Thanks;
    Gus
    Hi Gus,
    Use RIPUP on an edge of the polygon. HELP RIPUP
    Richard
