EAGLE User Support (English) 4 Layer PCB via's in Eagle for BatchPCB
  • Views 338 views
StefanTh
StefanTh over 13 years ago
Hi
4 layer PCB with the setting (1+2*15+16)
A)
If I start the autorouting and let it execute with no "pre settings or dedications", will the autorouter just use the layers 2 and 15 as it use 1 and 16, that is, just use them to make the best routing ?
B)
How do I a tell EAGLE, before autorouting, only to use layer 2 for GND and only layer 15 for VCC but it can use layer 1 and 16 unrestricted for signalers ?
I want to use layer 2 as dedicated GND layer and later flood fill them so they can be used as heat sinkers.
C)
If layer 2 and 15 have bene floodfilled and I manually add a via, this will connect to all 4 layers, effectivly shortcuting GND and VCC ?
D)
What should I do to avoid to make a shortcut between layer 1, 2, 15 and 16 when manually placing out via's ?
Shall I add an area around the via's that make the area 2 and 15 restricted before flood filling the layer 2 and 15 or is it other ways to do it ?
Regards Stefan
    Stefan Olsson wrote:
    Hi
    4 layer PCB with the setting (12*1516)
    A)
    Learn by giving it a go. Read the manual and tutorial included in the DOCs
    folder of you installation.
    B)
    Place polygons on those layers and name them GND and VCC as required
    C)
    NO. you name the vias appropriately and it won't connect to a layer where
    the signal name does not match
    D)
    ways to do it ?
    Same as C. The via needs the correct signal name and thus will isolate
    itselef from other signals with  different names.
    Regards Stefan
    news.cadsoft.de
