EAGLE User Support (English) Capacitive pad pour
  • Subscribers 189 subscribers
  • Views 491 views
Capacitive pad pour
I'm laying out a board with a capacitive slider. The slider electrodes use a large footprint. I'd like to be able to route through this footprint - is using a pour the best option?
    Thanks for the info - I was asking specifically about Eagle though. I understand in general how capacitive pads work, I'm wondering what the best way to do this in Eagle is.
    The problem is that if I make a capacitive pad footprint, I can't route through it, which is inconvenient since capacitive pads are usually quite large. If I use a pour, it's less portable (I'd need to manually create a new pour for each design instead of creating a capacitive pad part).
  • bheemarao
    0 bheemarao over 13 years ago
    More information regarding PCB-Based Capacitive Touch Sensing have been explained in below application note from TI
    http://www.ti.com/lit/an/slaa363a/slaa363a.pdf
    Unsure of what you are asking but the following read my be appropriate for
    you.
    http://cache.freescale.com/files/sensors/doc/app_note/AN3863.pdf
    Warren
    news.cadsoft.de
