EAGLE User Support (English) How to use existing library parts for a new library item
  • Views 699 views
  • library
  • question
This may be a dumb question from a newbie...
I want to create a part (package, symbol, device) in a new library by editing an existing part in one of the supplied libaries. Can't find how to do such a simple thing.
Thanks for any pointers, Rob
    db wrote:
    Is there a simialr way to do this if I am trying to duplicate a part
    in the same library?
    "Jorge Garcia" <jorge@cadsoftusa.com> wrote in message
    news:kd9r9p$37p$1@cheetah.cadsoft.de...
    >> 3. Keep the library open, from this point on we will not open any
    >> additional libraries we will only expand trees in the control panel.
    >> 4. In the EAGLE control panel, expand the libraries tree and find the
    >> library that contains the part you wish to copy.
    >> 5. Expand the library and find the component you want to copy.
    >> 6. Right-click on the component you want to copy and select copy to
    >> library.
    >> Voila the part has been copied to the open library.
    >> hth,
    >> Jorge Garcia
    Sure, open your library and then from the Control  Panel view that same
    library, locate the device of interest and copy that to the open library,
    which is the same one.
    Because the names are the same it will ask for a new name for the device.
    Then, depending on the change you wish to make you may need to un-do
    connections, make a new package or a  symbol r make another variant etc.
    All the best
    Warren
    news.cadsoft.de
    Is there a simialr way to do this if I am trying to duplicate a part in the
    same library?
    library.
    hth,
    Jorge Garcia
    Thanks Jorge,
    Before reading your answer I did figure some things out and together with your description I understand the procedure now.
    I created my part by editing the one that looked somewhat like it.
    Perhaps my main mistake is trying to figure out everything right from the start (this is my first Eagle project).
    Rob
    Hi Rob,
    I hope you're doing well, we generally recommend that users copy
    existing parts from EAGLE's libraries into there own libraries. There
    are several ways to do this, I'll describe the one I find easiest.
    1. You need to know what library and what part within that library you
    wish to copy.
    2. Open the destination library(the one you want to copy to) or create a
    new library.
    6. Right-click on the component you want to copy and select copy to library.
    hth,
    Jorge Garcia
