EAGLE User Support (English) Subcircuits (redesignable)
  • Subscribers 178 subscribers
  • Views 684 views
is there a way to build sub circuits in Eagle?
I know about the duplicating script, but this would just create the
parts. Is there a way to group them together permanently to treat them
as one single part.
    Peter
  • esilviu
    esilviu over 17 years ago
    no way
    "Peter Meier" <Peter.Meier998@gmail.com> wrote in message
    news:gbor1n$f4k$1@cheetah.cadsoft.de...
    I know about the duplicating script, but this would just create the parts.
    Is there a way to group them together permanently to treat them as one
    single part.
       Peter
    Here is what I think could work:
    Let's say your circuit is something that you have a well known layout for,
    something that you can hand route without too much difficulty.  Then it is a
    simple matter of creating this layout and drawing the pads and parts
    outlines as a single package, defining a schematic symbol that's just a
    black box with inputs and outputs, and connecting it all together as a
    device.  Then you would have a "device" that would actually be made up of
    several smaller parts, permanently linked as an object that can be moved,
    rotated, mirrored, and so on.
    I've never tried this before, but I would think it could easily be
    accomplished and that it could work.
    "eSilviu" <Silviu.Epure@ugal.ro> wrote in message
    news:gbovbp$skc$1@cheetah.cadsoft.de...
    no way
    parts. Is there a way to group them together permanently to treat them as
    one single part.
       Peter
  • esilviu
    True, but should we design a new component in library for every group we
    consider to copy-paste?
    What if I would like to change position of a component in that group?! Shall
    I modify the library?! all instances of that group will be updated to the
    new configuration. It's not ok.
    and, ... for beginner seems odd and impractical
    So: NO, there is no practical way to do that quick and easy.
    "Dan Kaderabek" <sales@guardianwireless.com> wrote in message
    news:gbqljd$g54$1@cheetah.cadsoft.de...
    a simple matter of creating this layout and drawing the pads and parts
    no way
    as one single part.
       Peter
    On Mon, 29 Sep 2008 16:44:23 +0300, "eSilviu" <Silviu.Epure@ugal.ro>
    How do you expect this "copy-paste" operation to work with
    back-annotation?
    new configuration.
    Only if explicitly issue the command to update the project from the
    libraries.  It is not automatically done just because something
    changes in a library.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
  • esilviu
    "Robert Scott" <fake-email@szivuejdl.com> wrote in message
    news:48e18786.12480421@news.cadsoft.de...
    Just to kill your ideea:
    What if you use in a schematic/board two (or more) instances of that
    macro-component; And you want to modify only one of them?!!! How do you
    do-it?!
    (solution is simple: create a new component in library, that is 99% like
    first one)
    Peter Meier <Peter.Meier998@gmail.com> wrote:
    as one single part.
    Read the repeated hints about consistant copying SCH/BRD. It will cost you
    sweet and tears to do, but it is doable. Then you have copied instance of the
    piece of board, but the reference to the original board part it lost.
    Bye
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
