EAGLE User Support (English) Ground plane clearance setting
  • Subscribers 189 subscribers
  • Views 2750 views
scott216
scott216 over 13 years ago
Which setting in Eagle determines the distance between ground plane and the traces?
  • scott216
    0 scott216 over 13 years ago in reply to e14 Contributor
    Thanks.  I'll check out the DRC setting
    The distance between ground plane and the traces is determined by the
    ISOLATE  parameter only if it exceeds the distance specified in the DRC or
    net class settings. Generally you leave the isolate at 0 and specify your
    needs in the DRC spacing or net class spacings.
    All the best
    Warren
    Help polygon -> isolate
    r
