EAGLE User Support (English) Open EAGLE 6.4 Files in 5.11
  • Subscribers 187 subscribers
  • Views 787 views
I’ve been using EAGLE 5.11 for a couple years with no problems. I recently up-graded to 6.4 and because it frequently crashed I went back to 5.11. Unfortunately while trying to use 6.4 I made a number of custom parts and several PCBs which will not open in 5.11; I get the message INVALID DATA.
Is there anything I can do to recover these files so they will open in 5.11?
    0 autodeskguest over 13 years ago
    Am 20.06.2013 19:05, schrieb Eddie Toler:
    INVALID DATA.
    5.11?
    http://www.element14.com/community/message/80721#80721
    Try export-import.zip at the cadsoft download/ulp section
    Joern Paschedag
    INVALID DATA.
    5.11?
    It is well documented that V6 uses a completely different file format
    (XML) than V5 (binary) and there is no backward compatibility.
    For porting back anything to V5, you need to export it in V6 and import
    it into V5. For libraries, this is rather simple using the EXPORT
    command (generating a script which will build up the library when
    executed in V5). Maybe you need to edit the script if it contains new
    elements that are invalid in V5, but that can be dealt with.
    Porting back design files requires use of an export ULP, please have a
    look at the download section at CadSofts website. As mentioned above for
    the libraryies, it may require some manual editing to make the script
    work in V5.
    Tilmann
