EAGLE User Support (English) How to display complete net (multiple sheets) in Schematic editor
  • Replies 10 replies
  • Subscribers 179 subscribers
  • Views 1682 views
  • eagle
  • schematic
guido36
guido36 over 12 years ago
I was wondering if it is possible to display (or highlight) the complete net (on multiple sheets) in the schematic editor?
To explain this in more detail, I can tell how this worked in another tool I worked with:
- Open a schematic with multiple sheets.
- Select a net that is used on several sheets.
- The schematic editor showed in a dropdown box (which contains all the sheets) all the sheets which contains that particulair net in bold.
- When selecting these sheets, the selected net stayed highlighted.
Does this function also exist in Eagle (I am using Eagle 6.4.0)?
Now I am searching all the sheets to check were this net appears (with a bit of help with the cross reference labels).
Guido
    0 autodeskguest over 12 years ago
    tool I worked with:
    EXPORT NETLIST provides exactly this information, but in text format.
    The statistics_sch ULP does not contain this information (at least for
    V5), however it surely could. Maybe it was enhanced meanwhile, or
    someone (you?) does this now. Perhaps there also is another ULP for this
    purpose?
    Tilmann
    Am 05.06.2013 14:50, schrieb Guido Vermeulen:
    This can be done with my ULP 'find':
      - Either type, e.g. 'run find n$2' into the command line
      - or type 'run find' to display a dialog box.
    If a net is only available on ONE sheet, it is shown and highlighted. If
    a net is distributed over several sheets, you get the corresponding list
    of sheets you desire.
    The ULP can also find parts, gates, elements, nets, signals, busses,
    classes, mathematical values (e.g. '1k1' also finds '1100', '1.1k',
    etc.), packages, devices,...
    If you're interested in the ULP, I can send it to you.
    Andreas Weidner
  • guido36
    0 guido36 over 12 years ago in reply to autodeskguest
    Thank you for the responses.
    Andreas, I am very intrested in your ULP "find".
    I am quite new here, can you tell me how I can give you my email address without writing it down in this post?
    I tried already to mail you via this forum but I couldn't find your name in the member list.
    Guido
    0 autodeskguest over 12 years ago in reply to guido36
    Hello Guido,
    Am 06.06.2013 11:46, schrieb Guido Vermeulen:
    You can reply to my personal e-mail address, which is the one under
    which I write my posts. You should be able to see it in the FROM field
    of all my messages, or here:
       andreas.weidner@aei.mpg.de
    Cheers,
    Andreas
    0 autodeskguest over 12 years ago in reply to autodeskguest
    of all my messages,
    That crappy web interface at element 14 doesn't even show the FROM
    content...
    Tilmann
    Am 06.06.2013 13:34, schrieb Tilmann Reh:
    content...
    Ah, I was already wondering.... I now
      - tried to look at the web interface,
      - couldn't find it from the Farnell site,
      - tried it from the CadSoft site,
      - found it there, clicked and
      - nothing happened but an error message 'nothing found'.
        This was shown for ALL forums.
    It appears that either the element14 links on the CadSoft site are
    broken, or that something else is amiss...
    Andreas Weidner
    content...
    From the web sites, it is pretty well hidden indeed. At element14.com,
    you need to select "the knode", then "Forums", then "CadSoft EAGLE",
    then the appropriate group. It's really hard to make it worse.
    But try the link in the footer of Guidos post.
    Tilmann
  • guido36
    Hello Andreas and Tilmann,
    Thanks for your help. This find.ulp from Andreas is really working well and is indeed what helps me out.
    (wondering if EagleCAD is not intrested in your ulp because it is much better then the standard one image)
    Guido
  • guido36
    hmm tried to mark this item as "answered" but no idea how.
    maybe an idea to have an easy way to do this in the future.
    the element14 web forums related to eagle are only serving as a
    frontend to the original newsgroups hosted at news.cadsoft.de
    Lorenz
