EAGLE User Support (English) Can the select tool be made more intuitive?
  • Subscribers 178 subscribers
  • Views 469 views
  • gui
  • pcb
  • drafting
ngmeagle
ngmeagle over 12 years ago
This is either a bug or an unintuitive GUI.  If it isn't a bug, I'm sure there are some reasons for this behavior but this could be made more intuitive.
Expected behavior: text under cursor selected
Actual behavior: text not selected, boarder selected
See this video link.  The insert video tool doesn't seem to work for either uploading or making a Youtube link:
http://youtu.be/wg6AOPA8faE
-NGM
    0 autodeskguest over 12 years ago
    intuitive.
    I don't get your point.
    The whole eagle GUI is based on 'select command first then use it'
    And that is exactly what your video shows. You activate the move tool,
    then select a wire to move.
    Lorenz
  • ngmeagle
    0 ngmeagle over 12 years ago in reply to autodeskguest
    Eagle GUI works by 'select comand first then use it'
    I selected the command first then went to use it, except I clicked on text and instead of selecting the text, Eagle selected a line some distance away.
    -ngm
    0 shabaz over 12 years ago in reply to ngmeagle
    Hi Nathan,
    There are little cross-hair type markers next to each component on the screen; if you click on them, you can move the desired object.
    Personally, I'd like to see this behavior kept, although I can see it could be confusing for the first time.
