EAGLE User Support (English) Delete tNames
  • Subscribers 179 subscribers
  • Views 1268 views
  • tnames
  • oshpark
Delete tNames
I'm submitting to OSH park using Eaglecad - I run gen_silk to create my silkscreen and would like to delete tNames.  Even if a smash the part I seem unable to delete the names in the layer - It keeps complaining about back annotation.  Is there a way to easily clear and delete the tNames layer?
  • dwinhold
    0 dwinhold over 12 years ago
    Hi Ross,
    Click on the layer tab and scroll down to the 't' or 'b' part of the layer you want deleted. Click the highlighted blue tab so it isn't there then press apply. This way you can see your change before you press ok. if you happen to chose the wrong one just click the spot where the blue was and it will put the part of the layer back on when you press apply. Press ok or cancel when done. Hope this helped!!
    Dale
    0 Former Member over 12 years ago in reply to dwinhold
    Hi Dale,
    The issue is not that I want to hide the layer when working on the board, it is when I upload the brd file to OSH_park it uses the _tNames as the silkscreen along with _tSilk.  As I already have the silkscreen generated vi gen_silk in _tSilk, I would like to delete everything from the _tNames layer so that it does not show up during fab - At the moment both _tSilk and _tNames are there.
    Ross
    0 autodeskguest over 12 years ago in reply to Former Member
    It strikes me that this is one of the slight drawbacks of using a PCB
    fab who take Eagle files. The one I use are more traditional, meaning I
    have to run the CAM processor myself to generate Gerber files, which in
    turn means that I get full control of which layers contribute to the
    silkscreen. That said, I do always include the xNames layers for
    component identification, because it's useful and I'm not usually
    working at sufficient density to make it impractical.
    If you need to remove all names from the tNames layer for OSH_park then
    you will need to do the following:
    1) copy your brd file to a new one so that you aren't breaking your
    working version
    2) Make sure you have 'smashed' all of the components
    3) temporarily deselect all layers except tNames (and bNames)
    4) group select the whole board
    5) delete the group (ctrl-right-click)
    6) reselect all the other layers and save as the release to OSH_park
    0 autodeskguest over 12 years ago in reply to autodeskguest
    "Rob Pearce" <noreply@bdt-home.demon.co.uk> a écrit dans le message de news:
    l3hore$5tv$1@cheetah.cadsoft.de...
    It strikes me that this is one of the slight drawbacks of using a PCB fab who take Eagle files.
    The one I use are more traditional, meaning I have to run the CAM processor myself to generate
    Gerber files, which in turn means that I get full control of which layers contribute to the
    silkscreen. That said, I do always include the xNames layers for component identification,
    because it's useful and I'm not usually working at sufficient density to make it impractical.
    If you need to remove all names from the tNames layer for OSH_park then you will need to do the
    following:
    1) copy your brd file to a new one so that you aren't breaking your working version
    Instead to delete these attributes, after the "group" you could also just change for an other layer
