EAGLE User Support (English) How do I remove layers from the display/route list?
  • Subscribers 178 subscribers
  • Views 323 views
I have the Pro version of EAGLE, both v4.16r2 and v5.3.0.  Lately I've
been working on 2 layers boards (layers 1 and 16),  but the display
list of layers always includes layers 2 - 15.  When I manually route a
trace, layers 2 - 15 are also displayed, so I have to ignore the extra
layers in the list.  In DRC/Layers, I have (1*16), so why do I see
these superfluous layers?  EAGLE won't let me delete internal layers,
so what do I do?
-Dave Pollum
    so what do I do?
    -Dave Pollum
    See the Eagle ver 5.x layers help and the example "mylayers.scr" at the
    very bottom. Set used_layers....
    Gruß / regards
    Jörn
    so what do I do?
    -Dave Pollum
    See the Eagle ver 5.x layers help and the example "mylayers.scr" at the very bottom. Set used_layers....
    Gruß / regards
    Jörn
    I have the same 'problem', never seen it as a problem though...
    mylayers.scr does not list 2-15 and the DRC is (1*16)...
    Set Used_Layers 1  16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 \
                    31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 \
                    47 48 49 50 51 52   91 92 93 94 95 96;
    DISPLAY NONE 1 16 17 21;
    yet they are there.
    On Sun, 16 Nov 2008 12:42:27 +0100, Joern Paschedag
    so what do I do?
    -Dave Pollum
    Thanks for the tip, Joern!
    -Dave Pollum
  • Richard_H
    Richard_H over 17 years ago
    so what do I do?
    -Dave Pollum
    You could modify your layer setup and then set it back to the
    original setup.
    For example, change your (116) to (12*16), click "Apply", revert
    it to (1*16) again, click OK.
    Now only 1 and 16 should be visible in the DISPLAY list.
    HTH
    Richard Hammerl
    autodeskguest over 17 years ago in reply to Richard_H
    On Mon, 17 Nov 2008 09:17:09 +0100, Richard Hammerl <ric@cadsoft.de>
    so what do I do?
    -Dave Pollum
    original setup.
    HTH
    Richard;
    That worked great!  Thanks.
    -Dave Pollum
