Anyone know a Ubuntu howto to install the newest eagle 5.3 on my 64-bit
Ubuntu box. Also, does the download from the CadSoft website support
64-bit?
Z.K.
64-bit?
Z.K.
64-bit?
Z.K.
Open a terminal window in Ubuntu.
login as sudo
type sh "and the directory path where you have eagele"
I usually just drag and drop the eagle down load into the terminal window.
As for 64bit systems I don't know if it will work.
EAGLE user wrote:
64-bit Ubuntu box. Also, does the download from the CadSoft website
support 64-bit?
Z.K.
login as sudo
It does. I just used the file on their website and it seems to work
just fine. I was having trouble downloading because I had my router
firewall set to high. I have never had any trouble with any other
website, but after putting down to low just to download their files it
worked fine.
Z.K.
Z.K. wrote:
support 64-bit?
Z.K.
login as sudo
window.
worked fine.
Z.K.
I can confirm eagle loads and works om my machine, 64 bit dual core AMD
athlon, on Ubuntu 8.10
If you upgrade from 8.04 make sure you nuke "/" and "/usr".
It should do it but I've seen it fail.
HTH
Richard
