EAGLE User Support (English) Device pin connections on schemitic
  • Views 1208 views
I have been looking for a tutorial or detailed explanation
of how to produce custom device profiles in the eagle library.  There is something I am missing; I cannot seam
to get my attempts to make a simple device work as expected.
I am designing a board that will have a number of Molex KK
3.96 mm pin connectors on it. Since I was unsuccessful at locating any existing
library devices with a  3.96 mm pin pitch
I thought I could produce my own device profile by modifying an existing library
file.  I started with the MA04-1 pin header
profile in he con_lstb.lbr. This is essentially the same connector device
profile as I need with a pin pitch of 2.54 mm instead of the 3.96 m that I will
require.  My approach was to modify the  MA04-1 package so that the pads are centered
on a 3.96mm grid and save it as a different package variant. I then verified that
the pins are connected to the pads in the connect window for the device.
As a result of my efforts to make a new variant package neither
the original device nor my newly created variant are working as expected. I can
select this device and place it on a schematic as expected. The device symbol appears
on the schematic and package image appears on the board as expected. The problem
is I cannot seam to make any valid connections to the device on the schematic.
Any connection I attempt to make never appear on the board ratsnest , I get  ECR errors indicating no connection have bean
made to the device. No matter what I do I cannot make a connection to the pins
on the device.
What am I doing wrong?
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    Because the symptoms you describe are most
    commonly a result of having moved the symbol pins off their 0.1" grid.
    Schematic symbol connections MUST ALWAYS BE ON GRID and the grid should
    always be 0.1"
    Thanks that explains my issue.
    0 autodeskguest over 12 years ago in reply to e14 Contributor
    On 15/11/13 21:51, Darryl Dennis wrote:
    I am still very
    interested in what I did wrong; how I could successfully make my own
    device profile?
    I would recommend, for connectors, that you don't actually modify an
    existing part but rather create the new by a script (as suggested on
    another thread recently). However...
    You didn't say in the first post whether you had modified the "symbol"
    part of the device at all? Because the symptoms you describe are most
    always be 0.1"
    Thanks! that is what I was trying to find. I am still very
    interested in what I did wrong; how I could successfully make my own device profile?
    It seams that it should be straight forward.
    I would like to have a better understanding of the library files and how they
    are made.
    existing
    I've designed in a KK 3.96 on one board, so I must have found or (more
    likely) created such a library. If the latter I would have thought I'd
    have uploaded it to the CadSoft site. However, I don't see it there, so...
    As I thought. Check the "con-molex" library in the standard
    distribution. It has a range of KK-156 parts. 0.156" is 3.96mm
