EAGLE User Support (English) Attribute !     of part C4 not found in board
  • Subscribers 178 subscribers
  • Views 803 views
I am finishing up a design and I added a capacitor. I set the attributes
on it and copied it three times. C1 and C2 generate no errors in the
ERC. C3 has "Attribute (2 spaces) of part C3 not found in board" and
"Attribute ! of part C3 not found in board"  C4 has the same to errors
plus 15 errors of "Attribute ! (several spaces - each error with
additional spaces) of part C4 not found in board"
Any suggestions?
TIA!
  • Richard_H
    Richard_H over 17 years ago
    Any suggestions?
    TIA!
    Which EAGLE version do you use? I think this is a problem that
    should be in the current EAGLE 5.3.5 beta.
    ==>ftp://ftp.cadsoft.de/eagle/betatest
    Richard Hammerl
    Any suggestions?
    TIA!
    Thanks for the quick reply!
    I should have put the version in - 5.2.0 on Linux. I see there is a
    released version of 5.3.0. Do you suggest I try that?
  • Richard_H
    Any suggestions?
    TIA!
    should be fixed in the current EAGLE 5.3.5 beta.
    As far as I know 5.3.0 won't help. Try the current beta 5.3.5.
    There it should be fixed (Sorry  for the typo above).
    Richard Hammerl
    Any suggestions?
    TIA!
    That did the trick! Thank you!
