EAGLE User Support (English) How can I select components booth in schematic and layout at the same time?
  • Replies 21 replies
  • Subscribers 190 subscribers
  • Views 6869 views
malevil
malevil over 12 years ago
I've seen and used this practical feature in an other designer system. However if I select let's say IC1 in schematic and move to the layout there is no selection for IC1 at all...
Is there any solution for this?
Zoltan
    0 autodeskguest over 12 years ago in reply to RayA
    Just testing to see how the Github Gist thing works...
    embedded GitHub Gist: fcd062514e58e790a7e0
    http://www.element14.com/community/message/105435
  • RayA
    0 RayA over 12 years ago in reply to autodeskguest
    To Doug and Lorenz,
    Thank you both for your help. I think this will be useful during every new design. This would be nice to have built in to a new version of EAGLE, so it's only a right-click away. (In case I ever get around to upgrading to the latest rev. ;-)
    Lorenz... Your tip about creating an empty group in the board editor did the trick. It works on 5.11.0 now.
    Ray
    RayA wrote:
    I have also tried it on my Acer laptop, Windows 7 Home, EAGLE 5.11.0
    Standard. Same results.
    If I select a group in Schematic, then run pickgrouped in schematic, it
    switches control to the layout editor with a message at the bottom of
    the screen "No group selected.".
    If I do the same thing, but run pickgrouped from the layout editor, it
    pops up a small message window that says "Nothing grouped in schematic."
    In both cases, I can still see the grouped items highlighted in the
    schematic. Maybe it's a difference between EAGLE 5.11 and 5.12? Or maybe
    there's a really simple step in the process that I'm not getting?
    the in/set/clrgroup functions have been introduced with V5.0
    there have been various bugfixes in V5.11, V5.12 & V6.0 since.
    I'm using 6.5.2 in the moment, so for me pickGrouped.ulp just does
    what it's supposed to do 8-)
    I remember though, when I cobbled together the first version(s) of
    this ulp, that there were some problems.
    I think to remember that the "No group selected" error could be
    circumvented by creating an empty group in the board editor first.
    Lorenz
  • RayA
    0 RayA over 12 years ago in reply to AnalogNotes
    I have also tried it on my Acer laptop, Windows 7 Home, EAGLE 5.11.0 Standard. Same results.
    If I select a group in Schematic, then run pickgrouped in schematic, it switches control to the layout editor with a message at the bottom of the screen "No group selected.".
    If I do the same thing, but run pickgrouped from the layout editor, it pops up a small message window that says "Nothing grouped in schematic."
    In both cases, I can still see the grouped items highlighted in the schematic. Maybe it's a difference between EAGLE 5.11 and 5.12? Or maybe there's a really simple step in the process that I'm not getting?
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to RayA
    I'll load 5.11 on my Macbook this weekend and see what happens...
  • RayA
    Doug,
    I'm using EAGLE 5.11.0, on an I-Mac, running OS-x 10.5.8, with two monitors.
    When I select a group in Schematic, then run pickGrouped, a message pops up at the bottom of the layout window that says "No group defined!". So it seems like it's trying to work, just not quite getting there.
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to malevil
    Zoltan Doczi wrote:
    Thanks a lot Doug for sharing this!
    Just to be sure ("credit where credit is due" as they say) I didn't write the script, Lorenz did.  I just cleaned it up slightly and posted it...  image
  • malevil
    0 malevil over 12 years ago in reply to AnalogNotes
    wow, wow and wow image
    Its works like a charm on my Win7 (x64) + 6.4 Eagle!
    After I select the components in the schematic, and run the script it's automatically select the parts in the layout, switching over the focus immediately. Thanks a lot Doug for sharing this!
    Best Regards,
    Zoltan
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to AnalogNotes
    Tested on Macbook with EAGLE 5.12.0, worked fine.
    Vista with 5.6 failed.  Clrgroup() was added in the next version...
  • AnalogNotes
    That's odd...  Bear with the silly questions for just a second please, but what version of EAGLE are you running, and what kind of computer and OS do you have?
    FWIW, I tested on a Windows 7 computer with EAGLE 6.5 and I can run the script from either schematic or board.  I'll test on my Vista box and Macbook when I get home tonight...
