EAGLE User Support (English) Can not rename Polygon
  • Subscribers 178 subscribers
  • Views 782 views
Seems basic, but I'm having a hard time with this.
I create a polygon on the bottom layer of my board. When I click properties
the Signal name is N$2.  When I try to rename signal by replacing N$2 with
AGND a message says AGND already exists and that I need to use the NAME
command to combine the signals.  The command "NAME N$2 AGND" results in "N$2
cannot be found" or doesn't exist or something.
Any thoughts?
  • esilviu
    esilviu over 17 years ago
    I've complain to Cadsoft about Info dialog on one component, but - as
    usual - they don't listen....
    If the Name text bos is editable, Eagle should permit user to set any name
    for that net/component.
    But this is not happening: you can't rename a net to a net that allready
    exist  in schematic (you can't connect the net you clicked "Info" with the
    an other net, usig THIS EDITABLE NAME TEXT BOX). You should use Rename
    button + click on the N$2 net, and then set the name to AGND
    "Mark Longerbeam" <markl@bmesystems.com> wrote in message
    news:gi6v2h$v23$1@cheetah.cadsoft.de...
    properties the Signal name is N$2.  When I try to rename signal by
    replacing N$2 with AGND a message says AGND already exists and that I need
    to use the NAME command to combine the signals.  The command "NAME N$2
    AGND" results in "N$2 cannot be found" or doesn't exist or something.
    Any thoughts?
