EAGLE User Support (English) Eagle Multi layer boards (4)
  • Subscribers 181 subscribers
  • Views 379 views
GP100
GP100 over 12 years ago
Is there a good tutorial for using more than two layers in a design. We have a requirement for a 4 layer board and was wondering where I could find information for setting these layers within eagle
    ftp://ftp.cadsoft.de/eagle/userfiles/doc/eagle_pcb_v5.x.pdf
  • dukepro
    0 dukepro over 12 years ago
    Not sure about the tutorial, but the easiest thing to do is to go to the
    DRC settings, and select the Layers tab.
    In the text box, enter "(1215*16)".  That will use vias through all
    layers.  For blind or buried vias, you'll have to jump into the docs.
    It's somewhat cryptic and I don't know it right off the top of my head.
    HTH
        - Chuck
    I have not seen a tutorial but use eagle for a lot of multi layer designs. The easiest thing to do is simply start with an existing 4 layer design and libraries. Otherwise the setup can be more involved (tedious) than you might think.
    Steve
