EAGLE User Support (English) Library Component for a SMD 10Way Single in Line Header 2.54 Pitch
  • Subscribers 179 subscribers
  • Views 335 views
  • eagle
  • library
haroldjclements
haroldjclements over 11 years ago
Hello forum....
I am tearing my hair out looking for (what I would consider) and everyday standard part. I am looking for an SMD 10Way Single In Line Header with a 2.54 Pitch (FCI 95293-101B10LF). I know someone is going to say "make one", but I would have thought that there would be one already.
If anyone could help me find this component, I would be much obliged? I find the search utility in Eagle quite frustrating at times.
Thanks in advance for your time,
Harold Clements
PS. Same part as Farnell: 9689532
    already.
    It's not there.
    For searching for packages I don't use the search from the control
    panel. That is frustrating. I open a board editor and start an add from
    there. That searches for packages more efficiently and you can scan
    through them quickly to see the matches.
    The attached script will give you most of what you want in the package.
    Run it in your library where your through hole 1 x10 header is and add
    this package as a variant remembering to specify a variant name and
    connect the pins to pads.
    HTH
    Warren
    1x10-SMD_HEADER.scr.zip
    0 Former Member over 11 years ago in reply to autodeskguest
    Hi Warren,
    If you don't mind, how did you create the script? Was it written manually in a text editor or was it somehow exported from the within the Library Editor GUI?
    ATB,
    0 autodeskguest over 11 years ago in reply to Former Member
    Daniel Wainwright wrote on Mon, 10 February 2014 05:34
    Hi Warren,
    the
    Library Editor GUI?
    Added the package to the Eagle library by copying the Through Hole
    equivalent
    Made the changes to PAD/SMD, tPlace, tDoc
    Exported the library as a script. That exports all the library ( The whole
    lot)
    Deleted all but the new package
    Added GRID MM at the beginning and GRID LAST at the end
    HTH
    Warren
