EAGLE User Support (English) polygon void ver 4.16r2
  • Subscribers 177 subscribers
  • Views 165 views
Sorry if this is an old subject, only just got round to using my v4.16
Is there a way to do a polgon void on a "normal" layer used for drawing
polygons to be used for power supplies . I want a permanent void in a
polygon(1). So far I can only think to draw another polygon(2) with a higher
rank inside (1) and then delete this polygon(2) to leave the void.  However
this is prone to forgetting to do to the delete.
TIA for any advice,
Dave Wells
    drawing polygons to be used for power supplies . I want a permanent
    void in a polygon(1). So far I can only think to draw another
    polygon(2) with a higher rank inside (1) and then delete this
    polygon(2) to leave the void.  However this is prone to forgetting to
    do to the delete.
    This has come up a few times.  You can use two overlapping U-shaped polygons
    (same rank), each drawn around the void area.
    Merry Christmas,
    Bert Menkveld
