EAGLE User Support (English) How can I measure track lengths for differential pairs?
  • Subscribers 182 subscribers
  • Views 737 views
I've been using Eagle for a number of years now for a variety of circuits. I'm going to start on a couple of designs that need differential pairs. I understand the stackup and impedance calculations, how can I get Eagle to report the track net lengths so I can match pair lengths?
Currently use Eagle 5.11, might be tempted to upgrade if V6.x supports better analysis tools image
Ian
  • AnalogNotes
    0 AnalogNotes over 12 years ago
    Go to: http://www.cadsoftusa.com/downloads/ulps and type "length" into the search box.  There are a couple ULPs you can try...
    EDIT: That is, if the standard "length.ulp" doesn't do what you want...
  • anweid
    0 anweid over 12 years ago
    Am 24.02.2014 23:32, schrieb istedman:
    EAGLE 6 has direct support for routing differential pairs and can
    automatically do the meandering for you. Unfortunately, the method is
    not very intuitive, but it should work once you read the manual. Since I
    haven't used the differential tool earnestly (but just testwise), I'm
    not sure about its quality, but at least it's there, and you can test it
    by just downloading version 6 for free, checking the manual for
    'differential pair' and 'meander' and trying yourself.
    Andreas Weidner
    0 Former Member over 12 years ago in reply to anweid
    I have downloaded and installed Eagle 6.5.0, will see how I get on with it. This will also help consider the upgrade from V5 to V6.
    Ian
