EAGLE User Support (English) Can't Load Old Schematic
  • Replies 14 replies
  • Subscribers 189 subscribers
  • Views 2011 views
  • message
  • error
I have a schematic I did 2 years ago and now want to edit, but when I try to load it I get this error message: line 16474, column 66: redefinition of name 'SUPPLY1' in tag <part>. How can I fix this (or bypass it)?
Greg
    0 autodeskguest over 12 years ago in reply to e14 Contributor
    On 2/03/2014 1:05 p.m., Greg Marshall wrote:
    Warren,
    Below is the <parts> section with most of it snipped out. Note
    occurrences of "SUPPLY1" near the beginning and end:
    <parts>
    <part name="D1" library="diode" deviceset="1N4004" device=""/>
    <part name="FRAME1" library="frames" deviceset="FRAME_B_L" device=""/>
    <part name="C3" library="rcl" deviceset="C-US" device="025-025X050"
    value="0.1uF"/>
    <part name="C4" library="rcl" deviceset="C-US" device="025-025X050"
    value="0.1uF"/>
    <part name="C6" library="rcl" deviceset="C-US" device="025-025X050"
    value="0.1uF"/>
    <part name="C7" library="rcl" deviceset="C-US" device="025-025X050"
    value="33pF"/>
    <part name="C8" library="rcl" deviceset="C-US" device="025-025X050"
    value="33pF"/>
    <part name="SUPPLY1" library="supply2" deviceset="GND" device=""/>
    <part name="SUPPLY2" library="supply2" deviceset="GND" device=""/>
    <part name="SUPPLY3" library="supply2" deviceset="GND" device=""/>
    <part name="U2" library="uln-udn" deviceset="ULN2068B" device="N"/>
    <part name="C16" library="rcl" deviceset="C-US" device="025-025X050"
    value="0.1uF"/>
    <part name="F1" library="ptc-ntc" deviceset="B57164" device=""/>
    <part name="C17" library="rcl" deviceset="CPOL-US" device="E2-5"
    value="33uF"/>
    <part name="J1" library="GBM" deviceset="PWR-JACK-2.5MM" device=""/>
    </parts>
    And here is a similarly edited part of the <instances> section:
    <instances>
    <instance part="D1" gate="1" x="60.96" y="251.46"/>
    <instance part="FRAME1" gate="G$1" x="0" y="0"/>
    <instance part="FRAME1" gate="G$2" x="325.12" y="2.54"/>
    <instance part="C3" gate="G$1" x="111.76" y="233.68"/>
    <instance part="C4" gate="G$1" x="195.58" y="198.12"/>
    <instance part="C6" gate="G$1" x="330.2" y="116.84"/>
    <instance part="C7" gate="G$1" x="101.6" y="106.68"/>
    <instance part="C8" gate="G$1" x="116.84" y="106.68"/>
    <instance part="SUPPLY1" gate="GND" x="53.34" y="215.9"/>
    <instance part="SUPPLY2" gate="GND" x="109.22" y="91.44"/>
    <instance part="U2" gate="A" x="330.2" y="147.32"/>
    <instance part="C16" gate="G$1" x="332.74" y="182.88"/>
    <instance part="SUPPLY1" gate="GND" x="332.74" y="172.72"/>
    <instance part="F1" gate="1" x="38.1" y="251.46" smashed="yes"
    rot="R90">
    <attribute name="NAME" x="40.132" y="253.7206" size="1.778" layer="95"/>
    <attribute name="VALUE" x="43.307" y="253.492" size="1.778" layer="96"
    rot="R90"/>
    </instance>
    Does this tell you anything?
    Greg
    Thanks Greg
    The XML looks well formed. For some reason Eagle permitted a part of the
    same name or made an error when writing out during the save, Anyway your
    solution is fine.
    Since about v6.5 Jorge reports there have been more checks made when a
    board loads so maybe this is why it has shown up now.
    All the best
    Warren
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    Warren,
    Below is the <parts> section with most of it snipped out. Note occurrences of "SUPPLY1" near the beginning and end:
    <parts>
    <part name="C3" library="rcl" deviceset="C-US" device="025-025X050" value="0.1uF"/>
    <part name="C4" library="rcl" deviceset="C-US" device="025-025X050" value="0.1uF"/>
    <part name="C6" library="rcl" deviceset="C-US" device="025-025X050" value="0.1uF"/>
    <part name="C7" library="rcl" deviceset="C-US" device="025-025X050" value="33pF"/>
    <part name="C8" library="rcl" deviceset="C-US" device="025-025X050" value="33pF"/>
    <part name="C16" library="rcl" deviceset="C-US" device="025-025X050" value="0.1uF"/>
    <part name="C17" library="rcl" deviceset="CPOL-US" device="E2-5" value="33uF"/>
    </parts>
    <instances>
    <instance part="F1" gate="1" x="38.1" y="251.46" smashed="yes" rot="R90">
    <attribute name="VALUE" x="43.307" y="253.492" size="1.778" layer="96" rot="R90"/>
    </instance>
    Greg
    On 1/03/2014 3:37 p.m., Greg Marshall wrote:
    Warren, I looked at it with FOXE as you suggested, but have to admit
    that I know nothing about XML.  I didn't see anything suspicious in the
    structure, it simply had 2 occurrences of 'SUPPLY1' in both the 'PARTS'
    and 'INSTANCES' sections.  It's not clear (to me) that the 2nd
    occurrence in one section relates to the 2nd occurrence in the other,
    but by changing the name of the 2nd occurrence in each section to
    'SUPPLY31' the problem seems to be resolved.
    http://www.element14.com/community/message/105131
    If you are inclined, how about uploading here the section of the XML
    from  (inclusive)
    Your solution is probably a safe fix but I would be interested in seeing
    the original corrupt code.
    Warren
    Warren, I looked at it with FOXE as you suggested, but have to admit that I know nothing about XML.  I didn't see anything suspicious in the structure, it simply had 2 occurrences of 'SUPPLY1' in both the 'PARTS' and 'INSTANCES' sections.  It's not clear (to me) that the 2nd occurrence in one section relates to the 2nd occurrence in the other, but by changing the name of the 2nd occurrence in each section to 'SUPPLY31' the problem seems to be resolved.
    On 1/03/2014 12:26 p.m., Greg Marshall wrote:
    When I did the original design I archived the .sch and .brd files when I
    sent it off to have the board made.  Some time later I needed to look at
    the design, so tried to load it and got this error message.  At that
    time everything should have been exactly the same as before except that
    I had added some parts to the library (for another project - not any
    parts used in this design).  At that time I just used a PDF I had saved
    of the schematic and didn't worry about it because I didn't think I'd
    ever be changing the design.  Now I should be in exactly the same
    configuration.  I have downloaded the latest version of Eagle CAD, but
    am using the old version for this project just to be sure.  So other
    than the library additions everything should be the same:  Same files,
    same software, same computer, same OS.
    Of course, the likelihood is that I inadvertently messed up the file
    without realizing it at some point.
    I am proceeding, cautiously, with my changes.  I'll let you know if it
    blows up!
    I suspect Eagle hick-cupped on you in the past.
    The XML of the schematic file is quite easy to understand. With an XML
    editor like the free FOXE from First Objects you get a good view of the
    tree structure and tabs. That helps to see when the xml is malformed.
    Right at the beginning you said:
    ...error message: line 16474, column 66:
    You should be able now to see where the corruption occurred and change
    it properly
    All the best
    Warren
    0 e14 Contributor over 12 years ago in reply to AnalogNotes
    When I did the original design I archived the .sch and .brd files when I sent it off to have the board made.  Some time later I needed to look at the design, so tried to load it and got this error message.  At that time everything should have been exactly the same as before except that I had added some parts to the library (for another project - not any parts used in this design).  At that time I just used a PDF I had saved of the schematic and didn't worry about it because I didn't think I'd ever be changing the design.  Now I should be in exactly the same configuration.  I have downloaded the latest version of Eagle CAD, but am using the old version for this project just to be sure.  So other than the library additions everything should be the same:  Same files, same software, same computer, same OS.
    Of course, the likelihood is that I inadvertently messed up the file without realizing it at some point.
    I am proceeding, cautiously, with my changes.  I'll let you know if it blows up!
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to e14 Contributor
    I loaded up a design I did about a year and a half ago, and I got some inconsistencies myself.  Three of the errors are definitely related to library issues.  Hmmm...
    Do you by any chance have a different copy of the files from two years ago?
    And I'm probably full of silly questions, but are you using the same computer, same operating system and same version of EAGLE as you did when you created the design?
    There are a number of warnings in ERC, a couple of which were clearly not there before (such as a wire overlapping a pin).  That is, I did ERC on it 2 years ago, accepted a few warnings and fixed everything else.  ERC now shows a few "accepted" warnings, but I'm sure there used to be more, and some of the new ones make no sense.  I can easily fix them, but this is disconcerting.
    Is it possible that these inconsistencies are the result of changes to library components?  Only a couple of components have been edited and the errors are not necessarily related to those components.
  • AnalogNotes
    Did you run an electrical rule check?  If forward/backward annotation is working and you have a good ERC, I think you'll be in pretty decent shape.  Of course, just because the spellchecker passes doesn't mean the grammar is correct, so it would probably be good to go over the schematic visually, and if possible, use LTSpice.  At some point, you might use a gerber viewer to see if things look good too...
    As described earlier, I edited the .sch file to change the 2nd instance of "SUPPLY1" to "SUPPLY31" (a name that was not previously used) for the 2 different uses. The schematic now loads correctly and forward/back annotation to the board layout seems to work.  However, I'm still nervous about the integrity of this fix, so if anyone can better explain the situation I'd really like to hear it.
    Greg
