    • Avnet Boards Community
EAGLE User Support (English) Problem changing text ratio in library parts
  • Subscribers 176 subscribers
  • Views 911 views
Hi Eagle support.
I have designed a board in Eagle 4.16r2, and was about to send it for
manufacture when I spotted that my target manufacturer (Olimex) requires
all silkscreen lines to be at least 10 mils.
So I'm trying to update all my packages to use 10 mil lines.
Olimex recommended for text to use 50 mil size with a 20% ratio in order
to get the right line width.
The trouble I'm having is:
1. Clicking Change->Ratio opens a dialog, I type 20, Enter.
    Then when I click on the existing text, it stays at 10%.
    It seems that the only way to fix this is to delete the text and
    re-enter it starting with the right width. Is this an Eagle bug?
2. Quite a few of my board symbols are smashed, so that I can move the
names to more convenient places. Unfortunately once smashed, it seems
the text cannot be updated to the right width when I follow step 1 above.
Please can you help, as it's currently driving me crazy!
Thanks.
Steve.
    OK, quick update on this issue.
    The ratio can be updated, but only if I also switch to vector font
    instead of the default proportional one.
    I have another self-inflicted problem now, as I was foolish enough to
    use a ULP from Olimex to "fix" my silkscreen widths. This seems to have
    simply cloned all lines / text in tNames, increasing the width in the
    process. It also means that if I try to move a symbol (or change text
    properties) that the cloned lines stay behind and litter the board!
    I had convinced myself I had backed up the board before running the ULP,
    but now I need it (a few days later) I can't find that backup.
    Is there any way to purge my board of any lines / text that are not part
    of a package? My hope is that by doing this, I'll be left with the
    original package drawings and text, that I can then go back and fix
    manually (properly) in the libraries.
    Ho hum, short-cuts never are, are they?
    Steve.
    board houses generally do not print the proportional font as it can't be
    represented in the Gerber files. to avoid nasty surprises when converted
      into vector font, you should always use vector font on your silkscreen
    and copper layers.
    in user options or preferences or some such dialog, you can force EAGLE
    to use only vector font on your layout ( and keep proportional in your
    schematic if you prefer ).
    as far as your corrupted texts, if they are on the same layer as the
    ones you want, you could try looking for your backed up autosaved files
    and find one that didn't have those changes. but i would just delete
    them manually. it may also work to smash all, delete everything on the
    layer, and then unsmash all to recreate the labels. but you would lose
    the positioning...i'd just delete them.
    as one who mistakenly sent a proportional silk screen to a board house
    and received labels in all the wrong places, i advise you to avoid this
    mistake and make sure everything on your layout is vector font...
    Ah ha! I had been looking for an unsmash option but hadn't figured it
    out. RTFM and of course it's there - hold the shift key.
    Thanks.
    Steve.
    yup, took me a few months to find it, finally searched the manual in
    desperation...
