EAGLE User Support (English) Running eagle on a high resolution display 3200x1800
  • Views 4035 views
trb.mchs
trb.mchs over 12 years ago
I am running eagle on a computer with a high resolution display. The icons are to small, is there a way to increase their size ?
  • rulekeeper
    0 rulekeeper over 3 years ago in reply to autodeskguest
    Maybe Try this:
    - On your Windows PC got to your Eagle Folder like: C:\EAGLE-7.7.0\bin an Right-klick the Eagle.exe
    - Klick Properties > Klick Compatibility > Klick "Change High DPI-Settings" > Klick Checkbox Programm-DPI and choose "windows logged in" > a little further below Klick Checkbox override high DPI scaling and chossse "system (enhanced)"
    Now Start Eagle and you should have normal Size Icons
    0 autodeskguest over 12 years ago in reply to trb.mchs
    Thomas Blackburn <noreply-190060@element14.com> wrote:
    The above does not change the scale of the icons which is the main
    problem.
    Does any one have a work around ?  have things changed since eagle 7
    came out ?
    On a first test, V 7  doesn't change the icon size.
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
  • trb.mchs
    0 trb.mchs over 12 years ago
    The above does not change the scale of the icons which is the main problem.
    Does any one have a work around ?  have things changed since eagle 7 came out ?
    0 e14 Contributor over 12 years ago in reply to trb.mchs
    You can change the size of icons and text in Windows (both 7 and 8). I have just tried this on my monitor and it increases the size of the text in the top menu bar in Eagle but it doesn't seem to alter the Eagle icons themselves. (I use Windows 7 64bit.)
    To change the size of text and icons in Windows 7 right click on the desktop and select screen resolution and choose the option "Make text and other items larger or smaller".
    Under Windows 8 you should find a few more options under the Display menu of the Control Panel but I suspect it will be the same - i.e. I think Eagle needs to change its icons or you need to set a lower resolution for the screen (i.e. something less than its native resolution) but the latter is not a very satisfactory solution.
  • trb.mchs
    So an update from working on this, it seems that the software does not scale with the windows UI, or at least the icons do not.  The system is running windows 8.  Does any one know what registry settings that would control the icon size ?  as those should be able to be adjusted manually.
