EAGLE User Support (English) How to draw a White Rectangle on top of the PCB?
  • Subscribers 179 subscribers
  • Views 1231 views
I'd like to write something in a white space on the PCB.
How to draw a White Rectangle on top of the PCB using Eagle CAD 6.4?
Thank you for your time.
Hope to hear the answer soon.
    There's nothing guaranteed about white but...
    Normally, if you're using a professional PCB house, the silk screen
    Gerber will be rendered in white. This usually contains the tPlace and
    tNames layers (sometimes others, but those are most common). So if you
    draw a rectangle in the tPlace layer then it should end up as a white
    rectangle on the manufactured boards.
    0 Former Member over 11 years ago in reply to autodeskguest
    Thank you so much for spending your time.
    It's very helpful.
