EAGLE User Support (English) Updated a library and ALL pad shapes on the brd changed to round
  • Subscribers 180 subscribers
  • Views 408 views
bhhoyer
bhhoyer over 11 years ago
Overwrote Pad Diameter as well
Eagle 6.3
Shapes in DRC set to get pad shape from library
destroyed my board the day before ship ...
  • bhhoyer
    0 bhhoyer over 11 years ago
    exported the library from schematic using ulp and updated.
    pads have returned
  • bhhoyer
    0 bhhoyer over 11 years ago in reply to bhhoyer
    and now they're gone again
    does anyone have any idea what's going on?
    0 autodeskguest over 11 years ago in reply to bhhoyer
      I suspect you have more than one library with the same name. If that
    is the case and you perform an "Update all" then the first library name
    that matches will update the board. It could well not be the one you
    expect to update the board. Check your Options > Directories >
    libraries. The paths are checked in the order they are listed. Check
    there is no repetition of library names between paths.
    HTH
    Warren
