EAGLE User Support (English) Group Font Formatting
  • Replies 11 replies
  • Subscribers 179 subscribers
  • Views 1049 views
scott216
scott216 over 11 years ago
Is there a script or something that can format all the component names and values on my board so it's the same size?   I tried a group select with the Info tool, but that didn't work.  Only one item was changed.
    http://www.element14.com/community/message/110432
    use the change size or change ratio on the group.
  • scott216
    0 scott216 over 11 years ago in reply to autodeskguest
    Exactly how would I do that?  Right now I click on the info tool icon, then the group icon and I select a group names (they've been smashed).  I right click and select properties.  The info dialog box comes up, but only for one item.  There's no grouping.
    0 autodeskguest over 11 years ago in reply to scott216
    http://www.element14.com/community/message/110435
    Use the change icon not info icon.
    The change Icon in ver 4 gives the list of properties to change.
    The issue could also be you final click is canceling the group select.
  • scott216
    Using the change tool is an improvement. but I don't see how it works with groups.  I grouped some parts, used change tool to change the size, but nothing happened.  But if I click on each text item, it changes it to the size I just selected.  If I don't select any parts in a group, it works the same way.  So grouping doesn't seem to be doing anything - at least they way I'm doing it.  This isn't bad, but can I change all of them at once?  Is there a command line option that would do this?
    http://www.element14.com/community/message/110493
    try help group
    Also see http://www.cadsoftusa.com/training/tutorials
    search for the group command
    Am 26.04.2014 23:17, schrieb scott216:
    Group-> change size -> 40mil
    then right click to the group.
    The left mouse button does it on a single device
    the right nmouse button does it on the group
    hth
    Werner
  • dukepro
    0 dukepro over 11 years ago
    Scott,
    What you're forgetting to do is to smash the parts first.  Try these
    commands:
    1. Group all components
        disp tOrig bOrig tNames bNames tPlace bPlace;
        group all;
    1. Smash components in the group exposing the text origins
        smash (C>0 0);
    1. Group all components including the text origins
        group all;
    1. Change the font and the size of the text
        change font vector (C>0 0);
        change size 50mil (C>0 0);
    1. Restore the previously displayed layers
        disp last;
    The "(C>0 0)" represents a Control-Right-Click at the origin, which
    causes the command to operate on the group.
    Hope This Helps,
        - Chuck
    35185.att1.html.zip
  • scott216
    0 scott216 over 11 years ago in reply to dukepro
    Thanks Chuck, that's great info and should be a big help.
  • dukepro
    0 dukepro over 11 years ago in reply to scott216
    The ratio can also be changed in a similar manner.  If you're not
    familiar with it, the text ratio is the ratio of the height of a text
    cell to the width of the line used to draw the text.  Most board houses
    have a minimum line width of about 7 mils for the silkscreen layer.  So,
    for 50 mil text, a ratio no less than 7/50, or 14%, should be used.
    Thus, after you have all your text selected into a group, you can add
        change ratio 14 (C>0 0);
    along with the "change font" and "change size" commands.
    HTH,
        - Chuck
    7206.att1.html.zip
    0 autodeskguest over 11 years ago in reply to dukepro
    the 'C' modifier is not needed for group actions on the command line.
    While a right click (or 'ctrl right click' if
    Option.ToggleCtrlForGroupSelectionAndContextMenu is set to 1)
    performed with the mouse would open a context menu, this makes no
    sense when performing a simulated right click from the command line.
    Lorenz
