EAGLE User Support (English) Is it possible to delete part of the silkscreen of a parts footprint...?
  • Replies 8 replies
  • Subscribers 189 subscribers
  • Views 2839 views
  • footprint
I'm working with a design that needs to be 10cm on the x axis. My only issue is that one of the footprints has a silkscreen that measures 10.2cm. Is there any way I can cut off the last .2 cm of that footprint without editing the part? Is there a gerber editor? Some way within Eagle? Any help appreciated!
I've circled the area I'd like to "erase" on the right side of the board. .2 cm shaves off about to the right side of the pin labels, plenty of room. I have no need for the pin labels for that row.
    0 autodeskguest over 12 years ago
    Although, as someone else has already said, it's not normally necessary
    to trim the silk screen because the board house usually do it anyway, I
    have in the past doctored a few Gerber files for this purpose using a
    combination of "gerbv" (a free Gerber viewer/editor) and a text editor.
    0 autodeskguest over 12 years ago in reply to e14 Contributor
    On 9/08/2014 12:38 p.m., Nathan Coonrod wrote:
    Hmmmm ok thank you for the reply. Any idea if there is a gerber editor
    that could just "cut off" that area? I really want to avoid editing the
    package as I assume I'll have to re-route this board.
    Really, it is easy to modify your current board using Eagle.
    It looks like your board outline and a few connectors holes etc are a
    package.
    Often done for Arduino shields.
    So make a copy of the that package in your library and then modify that
    copy.
    After that is done and saved, back in the board editor REPLACE the
    current part with the modified version.
    HTH
    Warren
    0 e14 Contributor over 12 years ago in reply to sqkybeaver
    Hmmm ok I'll move the boundary and see if they'll accept it like that. If not, I'd rather pay a little more than rework this board. Thanks for the help!
  • sqkybeaver
    0 sqkybeaver over 12 years ago in reply to e14 Contributor
    The solid white line of the board outline can be moved simply by dragging it to the desired position.
    I'm not concerned with the looks at that part of the board. My fab house wont accept it the way it is though and another house is about 40% more expensive. Not the end of the world if I have to chose another house, but it'd be nice if I could just shave off that .2cm without extensive rework.
  • sqkybeaver
    How important are the looks of your board? any silkscreen outside the board outline will just be cutoff anyways.
    Its best practice to finish editing before you generate the gerbers.
    Hmmmm ok thank you for the reply. Any idea if there is a gerber editor that could just "cut off" that area? I really want to avoid editing the package as I assume I'll have to re-route this board.
  • sqkybeaver
    you can use the smash function to separate names and values from footprint. and then individually manipulate.
    but you will probably have to edit the footprint from the looks of things.
