EAGLE User Support (English) Draw lines on Eagle Schematic
  • Subscribers 187 subscribers
  • Views 2636 views
rickford66
rickford66 over 11 years ago
Using Eagle 6.5, is there is a way to draw a line on the schematic without said line being a wire?
Thanks.
    0 autodeskguest over 11 years ago in reply to rickford66
    On 11/08/14 22:07, rickford66 wrote:
    Ah yes, there we go.  I tried to move the wire from the nets layer to
    another layer but it wouldn't let me.  If I start that way, it works.
    Yes, there are restrictions on layer swapping because it's not supposed
    to be an operation that affects the fundamental design. So on the board
    you can swap between copper layers but not between copper and
    non-copper. Similarly the schematic editor won't let you swap a line
    between "NET" and anything else because that would change the meaning.
  • rickford66
    0 rickford66 over 11 years ago in reply to autodeskguest
    Ah yes, there we go.  I tried to move the wire from the nets layer to another layer but it wouldn't let me.  If I start that way, it works.  Thanks.
    If you draw a wire on the NET layer you have created a net. You probably
    don't want that.
    If you want a plain old drawing wire, place a wire on a layer like SYMBOL
    or INFO or create your own layer.(User defined layer)
    HTH
    Warren
  • rickford66
    So even though it has a net name, it's not going to give an error anywhere so long as it doesn't snap to any pins?
    Thanks.
    http://www.element14.com/community/message/123537
    Oddly enough the wire command will make a line (The net command makes
    wires).
    Just be sure that it does not snap to any components.
