EAGLE User Support (English) nodes dots in schematic
  • Answers 2 answers
  • Subscribers 186 subscribers
  • Views 1803 views
Using Eagle for the first time.
Can anyone tell me why there are no node dots when I join a line to component or join two components
together?
    0 dougw over 11 years ago
    Hi Darryl,
    Node dots are only needed where wires cross to indicate that the two wires are connected.
    The Junction tool allows you to add node dots wherever they are needed.
    Doug
    Am 24.08.2014 um 01:21 schrieb darryl tamura:
    together?
    http://www.element14.com/community/message/124567
    Maybe you use wires/lines instead of NETS.
    Also check a hook on options/settings...something like "set junctions
    automatic".
    Sorry I can't give you the exact name since I don't use the english
    version image
    Joern Paschedag
    As Joern indicated - make sure you are drawing your schematic with the
    "net" tool (not the "wire" tool).  That is NOT intuitively obvious that
    "wire" doesn't actually wire things.  Also, another way of shooting
    yourself in the foot - do NOT change the grid on the schematic or you will
    find parts not connecting correctly.  I learned the hard way.
    mikey
    Thank you everyone for your response. Your answers lead me to this...
    Under OPTIONS => SET => MISC
    There is a button that says AUTO SET JUNCTION
    But I would think this should already be a auto function - no?
    Thank you again.
