EAGLE User Support (English) 3D cad files from Eagle layout
  • Replies 11 replies
  • Subscribers 187 subscribers
  • Views 4283 views
Does anyone know how to generate CAD 3D files (like STEP files or something)
from a board layout?
I have been using Eagle 3D, and it works great(!), but it only generates POV
files that I cannot use in our Pro/Engineer mechanics CAD system.
Best regards
Soren
    It works!
    But it just gives me the outline of the board. No holes or anything. Right?
    "Christian Bohrer" <c.bohrer@azelectronic.fr> wrote in message
    news:gpnubc$i89$1@cheetah.cadsoft.de...
    I corrected, I've tried with an irregular board outline and it seem to
    working fine now.
    Could you try it once again.
    I've attached it with this post.
    Christian
    "Christian Bohrer" <c.bohrer@azelectronic.fr> a écrit dans le message de
    news: gpnou4$od6$1@cheetah.cadsoft.de...
    Could you send to me an export VRML (*.wrl) of this "thing" from
    ProEngineer?
    Maybe the four wires of your board outline are not consecutive.
    Could you try to erase your board outline and redraw the four segments
    consecutively (as for a polygon).
    Anyway, I'll try to repair that problem, keep me posted.
    Christian
    "Søren Theodorsen" <theodorsen@proxeon.com> a écrit dans le message de
    news:
    gpnmo2$d7q$1@cheetah.cadsoft.de...
    It does not work for me. I use ProEngineer import feature.
    The width of PCB looks right (1.6mm) but when it comes to sketching the
    PCB, it looks like a big 'Z' and it should be a rectangle.
    Dont know what is wrong.
    Søren
    news:gp875v$qfn$1@cheetah.cadsoft.de...
    Hi!
    I wrote an ULP for IDF V3 (*.emn), but I dont know if it works because
    I
    didn't found an IDF viewer (free)...
    Please, could you try it and said me if it works, or not.
    Christian Bohrer
    news: gp3dlv$fig$1@cheetah.cadsoft.de...
    Forgot to mention that I did try the ULP generate_3d_data.ulp, but it
    did
    not work. It gives me an error message first "no board-outline on
    layer
    50
    found" then about the ULP: Negative array index used.
    Has anyone else tried to make Mechanics CAD files from Eagle files?
    "Søren Theodorsen" <theodorsen@proxeon.com> wrote in message
    news:gp31mm$p0n$1@cheetah.cadsoft.de...
    something) from a board layout?
    generates
    POV files that I cannot use in our Pro/Engineer mechanics CAD system.
    Best regards
    Soren
    working fine now.
    Christian
    ProEngineer?
    Christian
    news:
    Søren
    Hi!
    I wrote an ULP for IDF V3 (*.emn), but I dont know if it works because I
    Christian Bohrer
    did
    not work. It gives me an error message first "no board-outline on layer
    50
    generates
    Best regards
    Soren
    ProEngineer?
    Christian
    "Søren Theodorsen" <theodorsen@proxeon.com> a écrit dans le message de news:
    Søren
    Hi!
    Christian Bohrer
    did
    50
    generates
    Best regards
    Soren
    The width of PCB looks right (1.6mm) but when it comes to sketching the PCB,
    Søren
    Hi!
    Christian Bohrer
    Forgot to mention that I did try the ULP generate_3d_data.ulp, but it did
    50
    Best regards
    Soren
    See the attached file: idf_V3.ulp
    gp8gv7$en0$1@cheetah.cadsoft.de...
    I would be happy to give it a try.
    Where can I get this ULP?
    Søren
    Hi!
    Christian Bohrer
    did
    50
    generates
    Best regards
    Soren
    Søren
    Hi!
    Christian Bohrer
    50
    Best regards
    Soren
    Hi!
    Christian Bohrer
    not work. It gives me an error message first "no board-outline on layer 50
    Best regards
    Soren
    Hello Soren,
    At the moment I found 3 ways to export from eagle to MCAD (in my case
    Solidworks).
    -1- export dxf file and then import dxf file in MCAD an build board from it.
    This methode cost a lot of time. I always edit the dxf file so there was 1
    layer with the information i wanted to import.
    After importing you can build your board. Make an assembly and place the
    components on the board (from your own or internetlibrary)
    -2- export to a SAT file with acis-sat.ulp. This generates a sat file with
    information you can use.
    Cost little less time but to much in my opinion. With this ulp you get a
    regtangular board with all the holes in it.
    You have to edit the outline of the board yourself and you have to place the
    compnents yourself
    -3- Generate_3D_data.ulp generates 2 files an idl and an idb file. The
    problem is that this ulp isn't finished. Not every aspect for generating a
    IDF file are programmed in this ulp. for example the idl file will be empty
    because the things that are needed for the components are not
    there. An other problem is that there are some difficulties with cutouts in
    the board and you have mentiond the problem with the layer 50 yourself.
    It sounds like this is the worst one but infact this is the ulp I work with
    these days.
    I solved the layer 50 problem by editing the ulp and change the folow:
    int Layer3dBoardDimension = 50;
    to
    int Layer3dBoardDimension = 20;
    ( our Electronic Engineers are drawing the board outlines on layer 20, so if
    you use a different layer number
    please fill in that layer number)
    At this time I have no succes importing the componets as well. So when i
    imported the board I still build
    an assembly board with componets  on it.
    Eagle is intrested in building an good working IDF export but they haven't
    had the time yet. So
    till that time I keep on using this one.
    With regard,
    Joop Sleumer
    PBF Group BV
    The Netherlands
    www.pbfgroup.nl
    Best regards
    Soren
    did not work. It gives me an error message first "no board-outline on
    layer 50 found" then about the ULP: Negative array index used.
    generates POV files that I cannot use in our Pro/Engineer mechanics
    CAD system.
    Best regards
    Soren
    you see what you get image Draw your board-outline on layer 50. The ulp
    needs this to convert it to a idf/idb file. This files you can read by a
    cad-software like solid works ....
    best regards ggcode
    also search in the forum, there are many thraeds with 3d ....
    Try dxf.ulp (comes with Eagle).
    Best regards,
    Günther
