EAGLE User Support (English) Ratsnest not creating ground plane
  • Subscribers 180 subscribers
  • Views 1898 views
peterdegroot
peterdegroot over 11 years ago
I have a double sided board with ground planes on top and bottom planes. I have done this for another board and it has worked fine before.
Eagle creates the ground plane fine for the bottom layer but not the top layer. I have checked the polygon definition and it seems fine (name GND and solid fill). I have also deleted the polygon and recreated it.
Any ideas ? I have attached the brd file.
dualLM3886b.brd.zip
    http://www.element14.com/community/message/127145
    dualLM3886b.brd.zip
    If ratsnest is showing no airwires you don't have a ground on the top
    side. Add a via named to match the name of your polygon to connect the
    bottom and top polygon.
    Am 24.09.2014 um 23:35 schrieb Peter de Groot:
    dualLM3886b.brd.zip
    You have placed a POLYGON 'GND' over a Cutout-Polygon!
    Delete the Cutout-Polygon, then the GND-Polygon can filled the area!
    Alfred Zaffran
    • The new EAGLE V7 has landed *
                                 Web:   <www.cadsoft.de>
    Geschaeftsfuehrer: Mark Whiteling
    dualLM3886b.brd.zip
    Alfred Zaffran
  • peterdegroot
    0 peterdegroot over 11 years ago in reply to Former Member
    Ah Yes that's it. Thank you Alfred.
