EAGLE User Support (English) Connect vias in bottom plane, and increasing supply to smd pads
  • Subscribers 186 subscribers
  • Views 936 views
  • smd
  • pcb
  • vias
  • question
vebjornr
vebjornr over 12 years ago
2 questions:
1) how do i connect these two segments? (see pic) The vias have the same name as the net. but when i try to use the routing-tool in the bottom plane, it automatically pops back up to the top plane..
2) How to i increase the thickness of the "legs" that connect the smd solder pads, to the rest of the ground-plane? (also see pic)
    0 autodeskguest over 12 years ago in reply to autodeskguest
    On 27/09/2014 7:42 a.m., warrenbrayshaw wrote:
    On 27/09/2014 6:24 a.m., Rob Pearce wrote:
    On 26/09/14 17:59, Vebjørn Røed Myklebust wrote:
    2 questions:
    Which end are you starting from? The end of the airwire towards the top
    of the image doesn't come from the via, so starting there will be forced
    onto the top layer. Try routing from the other via, or using
    <ctrl>click. You may still need to re-select bottom after you start
    routing, but normally you shouldn't as long as Eagle knows you're
    starting from a via.
    The automatic connections to a polygon are formed at the wire width of
    the polygon, I think. Edit the properties of your ground plane polygon
    to have a sensible width.
    I see there is another problem with the Element14 front end to the
    EagleCad forums.
    Rob wrote "<ctrl>click" and only "click" is displayed by Element14.
    Fingers crossed that the double quotes in this message will assist here.
    Warren
    Nope that didn't work. So I'll try again using square brackets
    > Rob wrote "[ctrl]click" and only "click" is displayed by Element14.
    2 questions:
    EagleCad forums.
    Rob wrote "click" and only "click" is displayed by Element14.
    Warren
    2 questions:
