EAGLE User Support (English) Highlite of connected points in router does not work
  • Subscribers 180 subscribers
  • Views 500 views
  • manual
  • highlite
  • route
Hi guys,
When trying to route a board manually I don't see the highlite of the opposite connected point anymore. Did I switch this off by accident? I mean the behavior on this video:
Routing Signal Trace on Eagle PCB Layout
Reagrds,
Mischa
    I suspect you are using the WIRE tool to route with instead of the ROUTE
    tool.
    A Wire will not snap to the pad and pick up the signal name and thus will
    not highlight the airwire or destination pads.
    HTH
    Warren
    0 Former Member over 11 years ago in reply to autodeskguest
    You are so right ! Thank you very much !!image
