EAGLE User Support (English) Analog Electronics
  • Subscribers 178 subscribers
  • Views 312 views
Analog Electronics
Hello i am designing a operational amplifier, the project is to design an operational amplifier block to be used in a complex system-on-a-chip (SoC). I can either use a CMOS process from TSMC 0.35um HV CMOS technology, or a bipolar process from an unidentified foundary. The design must meet the requirements and it should be optimized for robustness, power, and/or speed. The design project is an opamp with the following characteristics: Gain>=60dB, Unity Gain frequency>=60MHz, Phase Margin>=45Deg, Offset<=50uV, Dynamic Rage =+/-6.5V (for 10mv error), Slew Rate>=80 V/us. The power supply is +/-7.5V. I need to know if Eagle can simulate all of the characteristics. I have my amplifier already mapped out with the values that i need i just need to simulate it. Is this possible?
    On 21/10/14 06:52, Adrian Coronado wrote:
    I need to know
    No. Eagle is a PCB design tool, it is not a circuit simulator and it is
    not an ASIC design tool. Perhaps you might be able to design an
    equivalent circuit and use the Spice integration, but that would not
    really be using Eagle, nor would it be properly representative of what
    you're trying to do.
    0 michaelkellett over 11 years ago
    Hello Adrian,
    Is this a commercial or  a student project.
