    • Avnet Boards Community
EAGLE User Support (English) Board DRC failure
  • Subscribers 173 subscribers
  • Views 297 views
Board DRC failure
Greetings:
    I have had, one one or two occasions, a failure in the DRC step
where a connection on the board between two nets was not detected
(i.e. an undetected short between two nets).
    The first time this occured, simply adding an unrelated trace or part
would cause the connection in error to be detected.  Also editing the
.brd file and changing the order of the "<wire x1=..." lines for the affected
net would cause the connection in error to be detected (not changing the
topology or appearance of the board, simply the order of the wires listed
for the affected net).
    This is with V6.5.0 (Linux) with an educational license.
    Has anyone noticed this and is there a workaround?
Regards & Thanks
-Willy
    On 10/27/2014 10:47 AM, William Robison wrote:
    Greetings:
    part
    affected
    listed
    Regards & Thanks
    -Willy
    Hi William,
    I haven't seen any such reports. If you have a sample file that can
    reproduce this issue, I would be very interested in seeing it, and I'm
    sure our developers would be too.
    If you can send a sample to support@cadsoftusa.com I would appreciate it.
    Best Regards,
    Jorge Garcia
    0 Former Member over 10 years ago in reply to autodeskguest
    Jorge:
        Thank you for the quick reply.
        After some additional digging about, I have come to the
    conclusion that the symptom I observed was simply the result
    of approving an "overlap error" or "clerance error".
    Ultimately I found the hash for the errors in the .brd file.
    Removing the line, of course, exposed the error.
    So no issue in the software. (PBKC:-)
        Again, thanks for your assitance.
    regards & Thanks
    -Willy
