EAGLE User Support (English) how do I set the origin
  • Subscribers 178 subscribers
  • Views 1211 views
  • eagle
eagle1301
eagle1301 over 11 years ago
Is there a way of re position the origin in a different coordinate when working on a new package?
Thank you.
    Am 22.11.2014 um 18:21 schrieb Rafael Sanchez:
    Thank you.
    http://www.element14.com/community/message/132594
    No, but you can move the package in relation to the origin.
    Joern Paschedag
  • engswee
    0 engswee over 11 years ago
    Dear eagle1301 (like army code)
    I not sure I get your question correct. For component package design in lib, you can change the origin of the component package by just moving the package.
    If you want to re coordinate in PCB design just select all and move group. The coordinate will be set to the new placement of part.
    If just want to re coordinate for one of the component.
    Then you need to open the component lib. Go to package. Select all and move group. The origin will be base on new component placement.
    Same to the new package just use select and move group.
    Remember to update lib in working design after the change in lib to make the change in the design. By select library and update.
    Hope you get the point image
    cheer
    ES
