EAGLE User Support (English) Multiple Supply
  • Subscribers 180 subscribers
  • Views 1291 views
  • multiple
  • voltage
  • schematic
  • supply
Multiple Supply
I'm drawing some schematics, and I want to use multiple supplies, eg. VCCINT, VCCAUX, VCCIO, VCCDDR, VTTDDR, VREFDDR, ..., in them.
What is the most simple way to do it?
(I googled and found some old pages. Thats said "define each supply symbols", but it's a so crazy way! It makes my library large and complex.)
naoy-y
    complex.)
    You don't need to use supply symbols.
    Net names are global. Simply name your nets correctly and LABEL them for
    clarity and documentation.
    Tilmann
    0 autodeskguest over 11 years ago in reply to autodeskguest
    complex.)
    I find it much to error prone using labeled nets for power supply.
    I don't mind creating special supply symbols as needed. It may be a
    bit of work initially, but as soon as you have a set of them ...
    Supply symbols have the big advantage to look like what they are.
    And even more important: they rename the nets they are connected to.
    Lorenz
    0 Former Member over 11 years ago in reply to autodeskguest
    Thank you for your reply, Tilmann and Lorenz.
    Hmm, global net name may work fine for my purpose.
    But as Lorenz says, supply symbols look like what they are, and it's the big advantage.
    Now I think placing symbol (the shape is supply symbol, but it doesn't have any pin) at the end of the supply nets is temporary solution...
    naoy-y
    0 autodeskguest over 11 years ago in reply to Former Member
    big advantage.
    have any pin)
    but then you have to name the net manually, and always make sure, that
    the (pinless) symbol matches the net name.
    And the net name is the crucial point here.
    A normal supply symbol (with pin direction 'sup' that is) will rename
    the net it gets connected to.
    And if you connect different supply symbols to the same net you will
    get a warning.
    Lorenz
    The best way is to use the symbol which display the connected net name automatically, I think.
    (And it's possible with other PCB CAD software e.g.. DesignSpark PCB... But with Eagle, We cannot define symbol only device, or display net name, which connected to a pin.)
    To define the symbols for each supply is very unproductive, and I'll never use that way.
    naoy-y
