EAGLE User Support (English) Resize PCB
  • Subscribers 179 subscribers
  • Views 1058 views
  • dimensions
  • resize
Resize PCB
I need to reopen an old project with a PCB size of 80x80mm (i use the Light Edition ver. 7.1) and i want add some components.
After resize the Dimension in Layer 20 from 80x80 to 80x100 mm i try to move some compoennts in this new space
but i always get this BRD error:
The Light edition of EAGLE can't perform the requested action!
Some objects extend outside the allowed board area.
The PCB is two layer and the size is within the Light Edition limits, how can i go ahead from this situation ?
Thank You
martino
    The light edition limits are, I believe, 100x80mm. If you're trying to
    make an 80x100mm board then it's outside those limits on the Y-axis. Try
    rotating it to be "landscape" instead of "portrait".
    HTH,
    Rob
    The size restriction is really an area restriction. You can use the
    rectangular area from the board editors origin at x=0 y=0 to x=100 y=80.
    Any part origin or pad cannot be outside that area.
    So if your design is displaced from the board editors origin, move it
    back there and you should get the desired size. You actually get 101 x 81
    HTH
    Warren
